C5 2.0 HDI wiring diagram
MyFault
Unread post by MyFault »
I try to find C5 2.0 HDI 2010 wiring diagram.
x 8085
Re: C5 2.0 HDI wiring diagram
What is your RPO, found on the tyre pressure sticker on the door pillar, and what part of the car do you need the diagram for? :)
MyFault
Thanks for the reply.
12351CJ. Correct?
Whole diagram is what I need. At first hydraulic unit and pump wiring.
x 1450
Unread post by xantia_v6 »
It is necessary to know which transmission is fitted and whether the suspension is H3 or H3+. There is no complete wiring diagram, just a set of 20 or so diagrams of different parts of the electrical system, which are specific to the build date and vehicle specification.
x 8085
I have moved this topic to this forum because it did not belong in Forum Announcements!! :)
MyFault
Ok. Thanks. Kind of you.
I'll check on tomorrow the gearbox type.
Like I said, hydraulic unit and pump is the part where I need correct wiring diagram for repair at first.
Kees
x 147
Unread post by Kees »
Maybe it's handsome to tell why you need it, it seems you have a problem with the suspension/ hydraulic pomp.
There are a lot of knowledge around here.
MyFault
Yes, I know around here is lot of knowledge and that's the reason I asked documents first. Maybe I need em to other issues too. U1217 U1118 is very common problems. In daily job it helps a lot take a look to the wiring diagram or plc-program how it should work. Plc I can forget with these cases.
