Firmware
Bouwmar
Firmware
Unread post by Bouwmar »
Hallo ben nieuw op de forum,
Ben op zoek naar firware voor mijn Citroën C4 Picasso uit 2013 type2
In de regelunit voor radio,kachel, navigatie, telefoon,enz zit een micro sd kaart. Deze is beschadigd. Weet iemand of heeft iemand waar ik de betreffende firmware kan vinden/ kopen om op de nieuwe micro sd kaart te uploaden.
Het betreft onderdeel 1610887480 en unit nummer 9805447880.
De oude kaart is beschadigd en probeert het systheem wel op te starten dan weer kort een kaart dan weer 20 sec radio maar slaat telkens weer uit.
x 5672
Re: Firmware
As this is a British forum, please post in English. Use a translator if needed, i.e. Google Translate or DeepL.
Bouwmar
Re: Firmware
Hello, I am new to the forum.
I am looking for firmware for my 2013 Citroën C4 Picasso, Type 2.
There is a micro SD card in the control unit for the radio, heater, navigation, telephone, etc. This card is damaged. Does anyone know or have where I can find/buy the relevant firmware to upload to the new micro SD card?
It concerns part number 1610887480 and unit number 9805447880.
The old card is damaged and attempts to start the system, sometimes briefly showing a card, then radio for 20 seconds, but it keeps shutting down.
x 1940
Re: Firmware
Unread post by Paul-R »
As you say there is an SD card inside the unit I suspect that it's an RT6, also known as eMyWay, WIPNAV+ and RNEG2. Compare your unit with these viewforum.php?f=44
If you know what firmware is fitted then this will prove it. Usually you can find this information by giving a long press on the Setup button, if you have one.
A photograph of your unit might also help.
Bouwmar
Re: Firmware
Hi paul-r
This is a smeg+
The firmware is the same as the car was delivered when new.
I only need the firmware to download to new MicroSD-card that i wil put into the control unit.
Do you have knowledge where i can get this?
