Hi!
We have a Citroen Jumpy 2015 model that has 190k km on it and most likely now has a broken double-damping flywheel. I want to know whether I can fit a fixed flywheel so it would last much longer next time around? Also, what is the correct dual-mass flywheel and clutch pack for my model?
120kw engine
One place says the engine code is RHH (DW10CTED4) (thanks for note in the vin it does say RHH)
(I have a VIN if it's needed)
One service manual only lists engine codes of DW10UTED4 (RHK) and DW10BTED4 (RHR) for 2.0 HDI and says it has a DVA flywheel on it and a LUK-made clutch.
I hope someone can help me find the right part, and also informing is it anyhow possible to install a fixed flywheel, since dual-mass ones are such a stupid design made to fail.
Jumpy / Dispatch 2015 2.0 HDi Dual mass fly wheel (DVA)
Patea
- x 1490
Re: Jumpy / Dispatch 2015 2.0 HDi Dual mass fly wheel (DVA)
190k km is not bad, just fit another, is the van really going to outlast 400k km / 20 years? Best advice is not to overheat them - don't hold it on the clutch on hills for instance.
PaulC5
- x 696
The engine code letters are in the VIN so from your post you should see RHH or RHK or RHR.
