Citroen Relay 2012 DPF ISSUE
vamzdis50
hi i just got my DPF cleaned report said it restored back to 100% efficiency . how ever ~200km after ecu calculated soot load of 230g and giving an warning about it then a week later it went into limp mode .i would assume DPF it self is ok rather ECU calculates soot load wrong based on some sensors ? DPF pressure on idle is ~30mbar so i am not sure where the issues is coming from or what is the formula used by ecu to calculate soot laod and weight ?
- x 8124
Re: Citroen Relay 2012 DPF ISSUE
Did you program the ECU that it had a new DPF fitted after completing the work?
vamzdis50
So dpf is not new it was just cleaned . and soot model was reset back to 0 before installing it . but then about two weaks later soot weight climbed up back to 220 i did a 160km drive on a motorway which dropped back to 120 and now after ~week its back to 260gmickthemaverick wrote: 22 Aug 2026, 21:26 Did you program the ECU that it had a new DPF fitted after completing the work?![]()
