I've got a 2014 208 and want to use Diagbox to investigate an SRS fault light..
Purchased a cheap adapter from AliExpress, but having problems getting it to connect.
I think the simplest solution might be to buy a new adapter and would prefer to get one from the UK. Can anyone recommend a reputable supplier please? Easy diagnostics only seem to offer their new adapter now.
UK supplier - lexia adapter.
- x 8134
Re: UK supplier - lexia adapter.
Indeed the loss of Easy Diagnostics has made buying Lexia products a minefield. However I have had a look across the market and this ebay seller seems to offer a good product. The kit comes with Diagbox 7xx and 9xx so should cater for vehicles you are likely to own. They have 100% positive feedback though only been trading for a short time. Full returns are available if the product is not as described so for the money that is where I would go at the moment. However should you choose to do so it is entirely your own decision as I am just giving an opinion. Good luck whatever you decide to do.
https://www.ebay.co.uk/itm/366590232521
- x 1940
It may be OK but that advert doesn't specifically say Full Chip Rev C. I would get confirmation from the vendor first.
- x 8134
Good point Paul, I read 'full diagnostics' and took it as full chip
At least that explains the price although the two versions of Diagbox was attractive as most of the ones I saw only offered 9.xx
rs101
Good news - my cheap adapter worked with a Diagbox virtual machine.
Bad news - it's reporting an SRS communication failure
