Door won't unlock.
Farid822
Door won't unlock.
Unread post by Farid822 »
Hi all. Got a bit of strange one. When I press unlock only side door opened others I have to use physical key to unlock it. When I press the lock button it works as it should. No fault codes. Thanks in advance
x 1941
Re: Door won't unlock.
Unread post by Paul-R »
Does anything happen if you press the unlock button a second or third time?
Farid822
Hi. No nothing happens only side door opens. I did Bai reset and reached the keys again.
Sloppysod
x 397
Unread post by Sloppysod »
When you say side door, do you mean just the drivers door? If so you have selective unlock activated, setting instructions are in the owners manual.
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
Farid822
Side door is back sliding door. I tried selective option on screen. Does not change anything
