Hi all,
Just got back from the exhaust garage to cure a blowing exhaust and spotted a leak of an oily type substance that appears to be coming from around the front Left Hand Side of the engine bay.
It seems to be in front of the engine near the mudguard area of the front spoiler, the fluid appears to be like oil and was not bright green and there seem to be some thin pipes that are coiled in that area.
Anyone know what this could be and where from, the haynes manual is as much use as a chocolate fireguard and I have searched the site for ages...
Car is a Xantia 1.8SX if that helps.
All the best
Andy
Leaking Xantia
np
johnny
Coiled pipes in the area you mention are LHM fluid pipes and I agree that if LHM fluid has not been changed for ages it could be brown/black in appearance.There is also a flexible pipe which runs from the bottom of the pressure regulator. Fluid could be leaking from the pipe to regulator joint (sealed wiyh an 'O' ring) and running along the pipe before it drips off.
Johnny
Johnny
Tuftus
CommY
