Air Conditioning System, 306TD
I recently had some corroded pipes replaced on my air conditioning system. The system was then regassed and it worked fine for about a day then failed again. On removing the radiator is was clearly apparent that the fluid was leaking from the large condenser that sits infront of the rad. Would it be possible for this condenser to be repaired or is it best advised to buy a new one at £120+ or second hand one from a breakers?
if you have trouble taking the pipes off the condenser, try the other ends, i think it goes to the pump and the drier/reciever. the bit with the sight glass on top. you shouldnt really have to take off the bumper, then you have to take the fans off,all the wires that run in front and it will be too much work to get into.
but tell us how you got on
