Peugeot Partner - display showing doors open permanently
petergabor
Unread post by petergabor »
Hi, my Peugeot Partner 2017 keeps showing left front door open which mean I aren't able to lock central locking.
I checked all wires from driver's door to connector on the pillar. I tried disconnect connector on pillar but display still showing opened door.
Can someone help me? I need wiring diagrams from driver's door to BSI. VF3**************[VIN obfuscated, can be read by forum staff]
PaulC5
x 683
Re: Peugeot Partner - display showing doors open permanently
Unread post by PaulC5 »
Try closing the door lock against a screwdriver to see if this makes a difference. I think the switch that tells the car the door is open or closed is built in to the door lock so it might need replacing.
petergabor
Thanks for reply. I tried it already. I had locking mechanism out from door and tested microswitch for door-open signal and it is good. I think problem will inside the car but without wirings diagram is problem find right cable on BSI.
