C5 X7 Glow Plug relay module
Paul_719_AB
Can someone please tell me the location of this module (1158). I have a glow plug fault and I want to check them via this plug rather than fighting my way to the back of the engine. I have a Citroen manual (on PC) but I cannot find any drawing which shows the physical location.
- x 8116
Re: C5 X7 Glow Plug relay module
This is the AI response from Brave's search engine, I don't know if it is any help to you. Good luck
The glow plug relay (module) for the 2010 Citroen C5 X7 (equipped with the 2.2 HDi engine) is located in the electrical box on the left-hand side of the engine compartment.
To access it, you must:
Remove the electrical box lid by undoing the fasteners.
Move the ECM aside by undoing the two Torx bolts securing it; note that the ECM does not need to be disconnected.
Unscrew the retaining Torx bolt securing the relay unit to the electrical box.
Lift the unit out and disconnect the wiring plugs.
This location is specific to the C5's engine bay layout; other Citroen models with different engines (such as the Relay van or 406) may have the relay located under the engine fuse box or near the passenger-side suspension strut, but the C5 X7 follows the procedure above.
