Hi.
Berlingo k9 2020 van. Keyless go.
Only way to lock this car from rhe inside is the door lock button on the dash.
I use this car as a mini camper, and that button is hard to reach from the boot.
Is there any wires in the boot i can mount a switch on to lock all the doors on the car?
Or do i need to run wires from the button on the dash to the boot.
Berlingo doorlock wires
- x 8126
Re: Berlingo doorlock wires
I would say the safest way would be to run a 2 wire cable from the front switch and connect a piggy back switch in parallel with it. Failing that you could always try a 15 foot fishing rod to press the front button while in the back!!
