C4 Coupé 2.0 HDI eletronic issues
VeigaN
Unread post by VeigaN »
Good morning, everyone!
I recently bought a 2005 C4 Coupé 2.0 HDI—a car I’ve always liked and a long-time dream of mine to own. However, I’ve been having a few issues and need your help.
I'm having symptoms like: sometimes it won't start, it's completely random, but then it starts after 1 minute, 5 minutes, or 10 seconds 😂. I thought it might be the crankshaft sensor, but I have other associated symptoms that are also completely random: the service light turns on randomly, low beam headlights flicker, central locking doesn't always work, side mirrors don't always unfold, and the tachometer RPM display has even failed to turn on once, then flickered before staying on for good. I'm starting to think it might be the BSI.
In your experience, what could this be?
I’d appreciate any help, as I'm getting desperate since this is my daily driver.
Thank you!!
x 8122
Re: C4 Coupé 2.0 HDI eletronic issues
With that many oddities I'd suspect the battery and BSI first. Is the battery showing 12.7V when all off and 14V plus with the engine running, ie the alternator is charging. I suggest you do a BSI reset following the procedure in the link below and then measure the battery voltages and see what you find. :)
viewtopic.php?p=601679#p601679
VeigaN
EDIT:
The windshield wipers also run randomly. The central locking also doesn't always work, and the key remote control doesn't work.
VeigaN
mickthemaverick wrote: 01 Aug 2026, 11:27 With that many oddities I'd suspect the battery and BSI first. Is the battery showing 12.7V when all off and 14V plus with the engine running, ie the alternator is charging. I suggest you do a BSI reset following the procedure in the link below and then measure the battery voltages and see what you find. :)
Hi!!!
Thank you for your reply.
I'll do what you told me, and then I'll tell you something.
x 1938
Unread post by Paul-R »
How many kilometres has it done? How old is the battery?
VeigaN
Paul-R wrote: 01 Aug 2026, 13:28 How many kilometres has it done? How old is the battery?
Hi!
198k km.
The battery is new. But I'll test it later today.
The car hasn't been driven in 3 years.
x 1938
Is the battery new before or after the three years?
VeigaN
Paul-R wrote: 01 Aug 2026, 13:41 Is the battery new before or after the three years?
2 weeks new!
VeigaN
So, I just measured it now and it’s 13.10 turned off and 14.4 turned on. I think the battery and the alternator are good, apparently. I’m going to follow the steps and do a reset as indicated in the link you sent me.
EDIT: It's still the same. After a few minutes the central locking no longer works again and the mirrors don't open.
x 1938
I think your next step will be to have the vehicle read for error codes (DTCs) with a high end diagnostic machine, preferably Diagbox.
VeigaN
Paul-R wrote: 01 Aug 2026, 15:16 I think your next step will be to have the vehicle read for error codes (DTCs) with a high end diagnostic machine, preferably Diagbox.
Thanks. I'm thinking on buying one. Until there I don't know what to do. Probably I'll to to an auto electrician.
VeigaN
Hi everyone,
The car has had no problems starting for three days now
Today I hooked the car up to the diagnostic tool and it showed the following errors:
P1434 (the only permanent one)
P0495
U1118
P1693
U2001
P0238
P1351
C1384
F998 (the only one that doesn't clear)
CEAC (This one is strange, because it's a 2005 unit, it doesn't have a DPF... or am I mistaken?!)
It said something about BSM, but I didn't take a picture.😖
