Me presento Citronero62, saludos a todos
Citronero62
Unread post by Citronero62 »
Hola tengo una Partner Tepee, que tenía problemas con la EGR.
La he desmontado, limpiado y he colocado una chapa con orificio de 10,mm.
También he limpiado caudalímetro y válvula de mariposa.
He cambiado filtro aire.
Mi pregunta es, tengo que rearmar los errores con un OBD, para que no me falte potencia ,como ocurría antes de hacer lo e todo este mantenimiento.
Gracias a todos.🫂
x 5672
Re: Me presento Citronero62, saludos a todos
This is a British forum. Please post in English. If necessary use a translator such as Google Translate, or DeepL as below.
Translated text:-
Hello, I have a Partner Tepee which was having problems with the EGR.
I’ve taken it apart, cleaned it and fitted a metal plate with a 10 mm hole.
I’ve also cleaned the air flow meter and the throttle valve.
I’ve changed the air filter.
My question is: do I need to reset the fault codes using an OBD scanner to ensure I don’t lose power, as was the case before I carried out all this maintenance?
Thanks, everyone.
Translated with DeepL.com (free version)
