Intermittent Limp Mode and No Starts
stephen_trainor
Unread post by stephen_trainor »
Hi all,
I have been having two distinct issues with my citroen relay van for quite some time now. Both issues seem to be worse on particular days with no obvious signs as to why.
1. The first issue is that the van fails to start when turning the key. Sometimes there is a click and sometimes nothing. I have checked the battery and even replaced it but to no avail. I also replaced the ground strap. Sometimes it takes 40 mins to start and sometimes it starts on a dime. I have had this looked at with multiple mechanics and they reckon the starter is just fine. After doing some searching I am being told this may be e gearbox to chassis earth strap issue so I am having that changed now. Also, one day when trying to start in gear which I did accidentally, one of the large fuses which I believe was the starter mega fuse over the battery blew which was quite concerning. I also had the starter relay replaced. After this I am going to dig around the enginer fuse box in more detail and then it will be onto wiring but just wanted to see if I am on the right track here.
2. The second issue is that the van goes into limp mode intermittently. I does seem to be when I put the foot down on the throttle but not always. Some days this never happens and sometimes it happens on motorways or when cruising at a low speed just after turning vehicle on.
I did a scan for fault codes recently and I got the following:
P0234 - Turbocharger, engine boost condition - limit exceeded
U1701(87) Archive (Inactive)
U0426(31) - Invalid Data received - immobilizer control module
I am planning to have a look at the actual pressure vs ideal pressure when accelerating using my OBD dongle but haven't done this before so will be a little bit of trial and error. I also read online that changing the boost pressure valve can solve this. I am not sure if I should just go ahead and buy this though as it's expensive and I don't want to change it if it's not necessary.
I have spent a lot of money trying to fix these issues to no avail and given the fact that this is a campervan that I converted myself it is quite valuable so I want to get it working again so I can enjoy it.
Any help would be highly appreciated.
Thanks,
Stephen
x 1940
Re: Intermittent Limp Mode and No Starts
Unread post by Paul-R »
How many miles has the vehicle done? How old is it?
parnell
(Donor 2022)
x 12
Unread post by parnell »
Which OBD dongle do you have ? I would recommend you to get diagbox working on a laptop if you can as that will provide a great deal of detail as to when and hopefully why those fault codes arose. I got a cloned full chip obd dongle as well as some rubbish Chinese version hacked - the second part I got a solution to via easydiagnostics.co.uk who provided a much better version of the diagbox software. Best of luck
stephen_trainor
Paul-R wrote: 27 Jul 2026, 16:00 How many miles has the vehicle done? How old is it?
Vehicle has around 170,000km and is 2015. L2H2, 2.2 HDI, Puma Engine
stephen_trainor
parnell wrote: 27 Jul 2026, 16:14 Which OBD dongle do you have ? I would recommend you to get diagbox working on a laptop if you can as that will provide a great deal of detail as to when and hopefully why those fault codes arose. I got a cloned full chip obd dongle as well as some rubbish Chinese version hacked - the second part I got a solution to via easydiagnostics.co.uk who provided a much better version of the diagbox software. Best of luck
I have a vgate vlinker mc+ which I heard was quite good. It does give a lot of data, not sure can you connect to the laptop but I might try it. Thanks
x 1076
Unread post by Rp0thejester »
I would suggest checking every vacuum hose for a split, a warm hose will leak more than a cold hose. As for not starting instantly, I had it recently but just held the key to start for about 15 seconds before my car started. I can only assume the unusual heat at the moment is causing issues.
