Citroen Relay 2020 - Eletrical Issues
jhjk34h5
Unread post by jhjk34h5 »
2020 Citroën Relay (35 L3H2 Enterprise BlueHDi S/S) – electrical gremlins, suspected BCM
Hoping for some input before I throw money at this.
Background: I've had a cluster of intermittent electrical faults. They don't all fire at once — it's almost like the BCM is cycling through them. Removing fuses doesn't stop it, and I can't find any shorts. The symptoms so far:
  • Van unlocking itself and setting the alarm off (most persistent and annoying)
  • Parking assist unavailable
  • Hill assist unavailable
  • Fuel gauge not stable
  • Central locking constantly locking/unlocking while driving
  • Battery draining from the van constantly unlocking and trying to arm the alarm
I also had an episode where the van lost power while driving — almost everything cut out, including the wipers — and each time it came back the odometer jumped 1–4 miles. That was during heavy rain, the worst I've seen it. I checked the ECU and BCM afterwards but couldn't see any water ingress on the modules or on any wiring I could get to.
UPDATE – latest and where I'm stuck:
An auto electrician has been through it. He found some wires near the fuel filter rubbing on the chassis and repaired those, but the issues are still happening. Also added a new earth at top of engine.
It's now getting worse and the van is becoming unresponsive. It'll start and do its usual weirdness, but when you stop the engine and lock the doors, the alarm goes off, then the key goes completely dead — you can't start it. The only fix is to disconnect the battery and leave it a good hour before it'll start again. The auto electrician reckons this is the BCM dropping into a failsafe/lockdown mode.
To rule things out, I've now got it stripped right back:
  • Both driver and passenger doors completely unplugged
  • Wiring harness to the rear of the van disconnected
  • A lead by the AdBlue tank that had corrosion — disconnected
  • Wiring to the exhaust/cat — disconnected
  • Tried starting with no fuses in the BCM at all (starts, no dash obviously, but the same fault still occurs)
So it's happening even with most of the vehicle isolated. My gut says the BCM is either going into that failsafe/lockdown state or it's losing comms with the ECU — but I don't have a diagnostic tool that'll show me which.
I'm reluctant to just fit a new BCM: if there's an underlying short or supply/earth fault, I'll have wasted the money and it'll do the same thing again. At this point I don't feel safe driving it.
Has anyone seen this failsafe/lockdown behaviour on a Relay/Boxer/Ducato, and what was the root cause? Any pointers on confirming a BCM-to-ECU comms loss without full dealer kit would be much appreciated.
x 8126
Re: Citroen Relay 2020 - Eletrical Issues
Having various parts unplugged will confuse the ECU and hence any diagnostic equipment you might use. I'd reconnect everything, carry out a BSI reset as per the link below and then run a diagnostic and see where you are. There are members with Diagbox who may be able to help, have a look through this list and follow the introduction to see if you can get some help: viewtopic.php?p=509922#p509922
The BSI reset procedure: viewtopic.php?p=601679#p601679 Good luck :)
