C3 desire radio not working
Oxytonesam
Unread post by Oxytonesam »
I bought a c3 desire 05 plate off a relative recently and can’t figure out the radio for the life of me. It’s original radio that came with the car, it seems to turn on but crash/freeze almost immediately, cd player seems to work but no audio coming out and can’t use any controls. Checked all the fuses, bought an aftermarket wiring harness to try a different radio with. Am a bit lost now as I know the radios are paired with the vin of the car so that stops me picking one up from a scrapyard and seeing as the harness didn’t work with the aftermarket radio, I don’t believe it’s the radio that’s the issue
x 1423
Re: C3 desire radio not working
Unread post by xantia_v6 »
Take a look at the thumbnails here viewforum.php?f=44 and see if you can work out which audio system you have.
Recoding the VIN of a head unit of the same model is not difficult with access to a suitable diagnostic tool.
Oxytonesam
Seems to rd3 from the serial number
Oxytonesam
However even if the radio was broke surely an aftermarket should work
x 1423
Oxytonesam wrote: 26 Jul 2026, 15:23 However even if the radio was broke surely an aftermarket should work
Your original post indicates that the head unit is recieving power, which should be most of what an aftermarket head requires to basically work.
I would suspect that the adapter lead is not correct for your car.
