308 GT Hybrid From 2021 blind spot issue
Kadange
Unread post by Kadange »
Hi everyone,
I recently bought a 2021 Peugeot 308 GT Hybrid from a professional dealership, and I would like to know the full factory equipment list using the VIN: VR3**************[VIN obfuscated, can be read by forum staff].
I am especially trying to confirm if my car has Blind Spot Monitoring. From what I understand, it should be standard on Allure and above. I have the two small LED indicators on both exterior mirrors, but I have never seen them turn on, even after driving on the highway.
Does anyone know how I can check the original equipment fitted to this car or confirm if the system is installed?
Thank you for your help.
x 8089
Re: 308 GT Hybrid From 2021 blind spot issue
Unfortunately the Forum has lost access to the VIN database so I cannot help you with a build sheet. However there are members with their own access and hopefully one of them will be able to help. Good luck. :)
Kadange
mickthemaverick wrote: 25 Jul 2026, 19:33 Unfortunately the Forum has lost access to the VIN database so I cannot help you with a build sheet. However there are members with their own access and hopefully one of them will be able to help. Good luck. :)
Thank you for you reply, hopefully someone with acces will be able to help.
