on the xantia. 1993 l reg 1.9td.
basically the back end is way too high. most xantias have the arch roughly in line with the top of the rear tyre. mine is about 9cm higher than this.
the height corrector is working as wheni move the lever it will go up and down etc.
do i therefore take it that the clamp on the anti roll bar needs to be adjusted to bring the ride height lower?
PLEASE HELP ME AS I AM STUMPPED
rear height corrector
tomsheppard
As you are new to Citroens and your username suffests that you are a former Ford man,
you need to know this. Any work beneath a Citroen requires axle stands to be placed very securely beneath the car. When the height corrector is adjusted, the car will crush you if you don't.
It is necessary to measure the level to which the car sinks before deciding to start fiddling with an adjustment that usually needs setting once (when the car is built) This still seems to be a height corrector linkage problem.
If the linkage has slop in it, it may well push the car up all the way but not be able to
release the car to lower fully.
Go and buy a Haynes manual and check out some of the sites that this forum links to. Without reading up a bit on these cars, you will never understand how they work. I've seen plenty of high tailed Xantias; Usually it is due to the HC linkage.
espzetec
espzetec
uhn113x
- x 3
As Tom says, it is unllikely that the ride height needs adjusting unless someone has been at it. The fact that the height lever works does not mean that the HC linkage is not sticking in normal operation.
HCs rarely wear out - they just get blocked with dirt from LHM. They can be stripped and cleaned quite easily.
To test HC, open boot, with engine running, sit on edge of opening, feet off floor. Car will go down - count how long it takes to rise. Get up, car will rise; count how long it takes to lower. Both times should be less than 15 seconds - if not, damper in HC is blocked. You can do the same at the front.
As an aside, how clean is your LHM?
espzetec
uhn113x
- x 3
Hi Mr zetec (or may I call you ESP?) [;)]
It does sound as if both HCs are in need of a strip and clean, but have a look at the colour of the LHM <b>first</b>. If it is dirty, the HCs will block up again. I am assuming that all the linkages are clean and lubricated.
If LHM is anything less than bright green and clear, like Creme de Menthe (disgusting stuff, but we digress) than it needs changing. If very dirty, you need to change it for Hydraflush/Hydraurincage and run with that for 1000m, than put fresh LHM in after cleaning filters. If still HC problems, they need to be removed and cleaned. I am sure that Anders or someone else has instructions on their site for this, but if not, I can run through it when you are ready
HTH
HTH
