2007 Citroen C5 MK2 BSI DIAGRAM
sydo
x 9
Unread post by sydo »
Hello, I need the BSI schematic for a Citroen C5 II. I would be grateful if you could share it with me, please.
Huskyxantia
x 901
Re: 2007 Citroen C5 MK2 BSI DIAGRAM
Unread post by Huskyxantia »
You were once asked to provide your vin number
:-D
Huskyxantia
x 901
Gemini ai reported
Because the BSI (Built-in Systems Interface / Boîtier de Servitude Intelligent) handles almost every electronic node in the Citroen C5 II—multiplexing the CAN bus networks between the engine ECU, suspension, lighting, and cabin comforts—there isn't just one single schematic. Instead, PSA separates them by specific subsystem circuits (e.g., starting, locking, lighting, or suspension) using standardized component codes.
​To help you trace what you need, the standard PSA wiring architecture breakdown for the C5 II BSI and its main connections includes:
​1. Primary BSI Supply & Fuse Matrix (BSI1)
​The BSI on the C5 II is primarily powered from the engine compartment fuse box (PSF1) via high-power maxi fuses (MF4 and MF8, both 80A lines).
​Main Feed: Check the heavy-gauge wires entering the black and grey main supply shunts at the back of the BSI unit.
​2. Common BSI Diagnostic Pinouts (OBD / Data Link)
​If you are troubleshooting a communication error or a dead network, the network lines map from the diagnostic socket directly through the BSI via these pin assignments:
​Pin 3: Diagnosis CAN H (Built-in Systems Interface connection)
​Pin 8: Diagnosis CAN L (Built-in Systems Interface connection)
​Pin 4 & 5: Body and Electronic Earth
​Pin 6 & 14: Inter-system CAN High and Low (communicating directly to the Engine ECU / BSM)
​3. PSA Schematic Component Codes to Watch For
​When parsing through a C5 II wiring diagram layout (such as the standard SEDRE digital manuals), look for these exact prefixes to find where the BSI interconnects:
​BSI1 / central electronic block: The BSI module itself.
​PSF1: The under-bonnet engine compartment fuse box/switching unit.
​IC02F / Main Interconnections: The pass-through multi-pin connector arrays that link the cabin harness directly to the engine bay.
​MC / M codes: The critical earth/ground points distributed along the chassis pillars that the BSI switches to complete component circuits.
​Since I cannot directly attach or render full multi-page factory PDF wiring blueprints here, let me know which specific system or fault code you are troubleshooting on the C5 II BSI (such as window regulation, central locking, or a starting/no-communication fault). We can map out the exact pin configurations, connector colors, and wire numbers for that sub-circuit to save you digging through the massive factory manual sheets.
:-D
sydo
x 9
Vehicle VIN number: VF7**************[VIN obfuscated, can be read by forum staff]. Regarding the central locking system (door opening and closing), which trigger cable is in the socket, which pins, and which colored wires? Thank you in advance for your help.
windy1603
x 8
Unread post by windy1603 »
These are the two main wiring diagrams for central locking on the C5 MK2
C5 M2 Deadlocking.pdf
(901.54 KiB) Downloaded 17 times
C5 M2 Standard locking.pdf
(867.66 KiB) Downloaded 15 times
