Drove the car 2 weeks ago , when got stuck , apperantly the dpf filter was completly blocked and become very red .
After that the urea light went on,conectted to lexia -urea injector short to earth, ordered a new injector , whould throw the same code even after reinitialize in lexia.
when im disconnecting the connector frum the urea injector , the fault chane to open circuit-so tha mean the wiring are not short to the body.
is the urea eco toasted? any ideas?
CITROEN c4 cactus BlueHdi urea
- x 8119
Re: CITROEN c4 cactus BlueHdi urea
Not sure I understand what you mean by 'eco toasted' ?piki wrote: 19 Jul 2026, 14:11 Drove the car 2 weeks ago , when got stuck , apperantly the dpf filter was completly blocked and become very red .
- x 1943
How old is the vehicle?
How many miles has it done?
I don't know what 'eco toasted' means either!
PaulC5
- x 682
Is the exhaust tail pipe white inside from too much adblue being injected ? Just trying to think how a urea fault and a blocked dpf could be related or has the injector wiring been damaged by the hot dpf.
- x 1488
piki
- x 5
Sorry guys .....
its 2018 done 220k km.
when the dpf was clogged . i stopped on the side of the road , and it was glowing red then the car whould start to give the urea fault, then when tested the injector, it wont give any resistence, so i replaced it with diffrent one.
my question was -if when a good injector is pluged in lexia show - short to earth,and when the connecter disconnected from the injector lexia show-open circuit, so that means -urea control module (or something like that ) is bad? what are my options? i tested with 2 working injectors...
the tail pipe is black . there is no white there....
- x 8391
The Urea Injector electrical connector requires a very firm (hard) push to correctly seat it. It is easy to get this wrong. It can feel like it's home bust isn't. You should hear a distinct click from it when it's properly home.
piki
- x 5
So why would lexia read a short ,if connector won't seat fully lexia would stay stuck on open circuit fault
piki
- x 5
Any idea?
- x 8391
Check the pins in the connector are not bent; they're quite fragile...
piki
- x 5
Will do that
