C8 phase 1 in 2026?
selma_true
x 4
C8 phase 1 in 2026?
Unread post by selma_true »
Hello,
last year I bought an estate Xsara phase 2 with modest 150000 km on the clock. Nice little car but turns out I have a need for a bigger one. I've been eyeing C8 and 807, was wondering what the users think about those cars after extended use. So please share your insights on what to avoid, look for etc.
What I'm trying to find is diesel, no electric doors, with the earlier HDI engine lineup (production year up to 2005?).
Some specific questions that came up:
- Is the difference between 2.0 and 2.2 HDI big enough in everyday use that I should specifically look for one or the other? How's fuel economy between the two?
- Is there any real significant difference between the 807 and C8? I thought the C8 seems to have better equipment from the ads I've been looking at.
- Many cars at least in Central Europe have auxiliary heaters, which would be good. Is it possible to mount a controller/clock to it so it could be used to pre-heat the engine?
Cities banning entry with old cars is not really an issue in this case since it doesn't change anything from my current Xsara :--)
x 8100
Re: C8 phase 1 in 2026?
One for our Ryan (RpOthejester) to answer I do believe!! :)
x 1068
Unread post by Rp0thejester »
I love my car!! Mines a 2.2 diesel 2006 model. Great for everyday use. Sliding doors are exceptionally useful in car parks. If you get one with a 'spoiler' fitted that's your roof rack sorted. Rear seats removable to turn it into a proper van. Don't really need the 2.2 diesel unless you're carrying a lot of weight all the time. If looking at getting one then get one with a service history and the lowest price possible. The engine is extremely difficult to work on as it's pushed back under the windscreen, so a turbo replacement would cost upwards of £1000, most of which would be labour cost to just gain access to it. As for fuel economy mine averages about 40mpg.
selma_true
x 4
Good stuff, thanks RpOthejester! All the cars I've seen here in central Europe have the spoiler/rack. About the seat, that's the one killer feature of this car. I used to have a 307SW with the removable seats and it was super useful. In C8 I imagine it'd be even more so since the car is pretty spacious.
I'll not obsess over 2,2 - 2,0 in that case, just need to find a unit that ticks my other boxes!
x 1068
All 5 rear seats are removable, I have the middle row removed as my son is 6'2" and still growing so he needs the leg space. As for C8, 807, Ulysses and Phaedra. There all the same just minor changes in bodywork and interior.
111two
Unread post by 111two »
Probably I am a bit too late but, hey, I'm rarely online and I've just seen this.
2005 C8 2.2 HDI
Everything that Ryan said, plus..
Spare parts available via eBay: there are four or five professional breakers based in Lithuania that have any single part in stock. And I mean, ANY.
Especially, if you are looking for one with more than 150.000 km check that this two jobs have been done already:
- Timing belt (and while you are there, water pump and ancillaries belt). I shopped around and had it done in Italy where I was on holiday for a bit more than €550 all included. Here in the UK it would probably have been a £800 job, if not more. Spares are not expensive but you need to take down a good part to the right of the car behind the wheel to access it. And it takes time. And labour.
- Clutch and dual mass. Or conversion to normal clutch and flywheel like I did. I found in Italy an original Valeo conversion kit for €210, if you browse eBay maybe you can find something similarly priced in your area. Otherwise the spare part costs a bomb on its own (more than £500+ here in the UK) plus, again a lot of time, therefore labour, and this alone can be double the cost of the spare part.
If they are not done, price the car accordingly.
Check that has been maintained.
Expect the occasional electrical hiccup due to age. For example, the windscreen washer pump on mine died literally yesterday.
Giangi
Hoarder of unloved cars.
x 1068
Great comments there, the C8 is very labour intensive but still worth it in my opinion. To give you an idea of how labour intensive this car is, here's a video on doing the timing belt. So remember to get the mechanic to check for any other faults whilst they are there
selma_true
x 4
Thanks for all replies! I forgot to check this thread. In the meantime I found an interesting "unicorn" candidate. I'm looking for a unit with <300k km, towbar, cruise control, aux heater, and all that for a reasonable price. As you might imagine, there are not too many suitable candidates, and most that appear are suspicious in one way or another (history of crash, odometer rolled back, rusted to hell, etc.).
However I found an interesting 807 which ticks all these boxes and also has sills repaired as a bonus. It has the 2.2 HDi 128 (DW12TED4) engine, which neither me nor any family member had before. I don't know if I should avoid it and look for my familiar 2.0 109 or newer 136? Any thoughts on whether to prefer or shun specific engines?
x 1068
I have the 2.2 HDI DW12TED4. It's as good as any other engine out there. Especially handy if your fully loaded or towing. It pulls like a truck. I would suggest test driving it up a very steep hill, it should keep accelerating steadily if it struggles it could be a sign of the dpf starting to block.
