is my Citroen ax on sedre?
ibog
Unread post by ibog »
Hiya..
I lost my sedre with a windows update a long while back.. but I've just acquired an old Citroen ax to rebuild.
so, I'm hoping a kind soul would take a quick look and check if the Citroen ax sedre manual has much missing..
my 2002 C5 wasn't covered very comprehensively, I'm guessing this 1992 could have little on there..
so not sure if it's worth the endeavour to re-instate my previous windows version at this point..
any help gratefully received 🙏
2003 C5 LX 2.0 hdi 90 RHY
2007 C3 1.1i TU1A (tbc)
2002 406 2.0 hdi 90 (retired)
1997 ZX 1.8D (rehomed)
1990 205 1.9 GRD (retired)
1989 205 1.8 GRD (rehomed)
x 8119
Re: is my Citroen ax on sedre?
Can you confirm engine, gearbox and trim level and I may be able to do something tomorrow pm. :)
x 8391
In the absence of Sedre, I'm sure there very little about an AX that's not well known and understood amongst those who regularly gather on this forum :)
I'm certain that between us we can tell you all you need to know...
x 2005
Unread post by Stickyfinger »
Parts and diagrams
Take care to double check and cross reference part numbers....I find using AutoDoc as a cross reference on the part name and number a good way to find alternative (Peugeot for example) part sources as well as checking suitability for a particular model in the AX range.
https://www.catcar.info/citroen/?lang=e ... NTOQ%3D%3D
x 1459
Unread post by xantia_v6 »
I don't think that SEDRE has much before 1998. The 1997 Xantia is not included.
I may have a link to some AX diagrams but would need to find it.
x 8119
For the asking price I'd suggest this may be worth a punt!! :)
https://www.ebay.co.uk/itm/127607825224
x 1459
xantia_v6 wrote: 19 May 2026, 10:10 There is an AX wiring diagram at:https://share.google/aqmD4KbNfkq2hDtaK
The text in japanese.
ibog
awesome, thanks a lot!!
ibog
mickthemaverick wrote: 14 Jul 2026, 23:41 Can you confirm engine, gearbox and trim level and I may be able to do something tomorrow pm. :)
Hiya,
it's technically a 1.0 debut 1992 not injected
but I will be putting a modded 1.4 in and replacing most of the rest..
x 2005
A hint (if you do not know) ...
On AutoDoc, find the part you want, at the bottom of the the parts page is a "active" small text line.....[]OE Numbers[] or []Show OEM numbers of the product[] .
Click on that, the result will be all the cross reference "other manufacturer" product numbers that the part can be replaced with.
You can then use these to find cheaper, OEM, faster supply or Ebay sources
x 8391
Stickyfinger wrote: 16 Jul 2026, 07:57 A hint (if you do not know) ...
Absolutely and I've found it invaluable on occasion. Saves a lot of guesswork...
