Citroen berlingo turbo/air intake sensor
Jasonlockman
Unread post by Jasonlockman »
Hi all
I have a berlingo 2012 B9.
The turbo has stopped working but vehicle still runs and drives, just a lot slower on pick up. Also noticed that the temperature on the van now stays around 75.
No smoke or rattles etc. only fault that came up was P0113 Air intake temperature sensor 1 circuit high.
They seem to be 3 sensors and was unsure of which ones be to change if a new one was required.
I scanned vehicle and once fitted the new parts and on live data, it did show temperature rising on air intake sensor when foot on acceleration.
I changed the one to the top left rear of engine, and also the one at the top front of engine. Both have not solved the problem.
Any help appreciated
Thanks 😀
x 8121
Re: Citroen berlingo turbo/air intake sensor
You may get some ideas from a read through this: https://club.autodoc.co.uk/obd-codes/p0113 :)
