Hi all,
My car was ovefilled with LDS and when I tried to depressurise the system some of it went into the pump. This was around a year ago and now the pump barely works and I would like to remove it myself and clean the motor. I found this thread:
viewtopic.php?t=60565
Which mentions the official procedure for removing the pump and I was wondering if anyone could share it?
Thanks in advance,
Hristo
Citroen C5 X7 official procedure for suspension pump removal
vodnasol
- (Donor 2026)
- x 8120
Re: Citroen C5 X7 official procedure for suspension pump removal
That thread you found with the reference to the official procedure also has a post from EDC5 explaining the operation as he carried it out following the procedure. You should be able to follow it from there
viewtopic.php?p=581404#p581404
