Peugeot 308 SW T9. Automated tailgate
CVR
(Donor 2026)
Unread post by CVR »
Hello to the forum, and thanks for a valuable source of info on the PSA cars.
I have a Peugeot 308 T9 year 2017. It has keyless entry, and remote unlock button on the keyfob.
I have installed an automated lift system on the tailgate. This can be operated by a positive or negative pulse.
However, since the doorlock are CAN controlled, I am missing the activation signal to remotely operate the tailgate.
The tailgate operates on the normal button handle, which sends a ground to the BSI. Then the BSI sends 12V to activate the lock, and in this case the tailgate ECU.
Is it possible to either locate the signal in the BSI? or to have the BSI coded to send 12v to the lock from the keyfob?
Brgds
Chr
x 8119
Re: Peugeot 308 SW T9. Automated tailgate
Hi and :welc:
I am afraid I can't offer any help on this one as the car is newer than the diagrams I have access to. Hopefully someone else will be able to help. :)
CVR
(Donor 2026)
The model is released in 2013. Is it possible you have info from that year?
Brgds Chr
x 8119
This is the best I can find if it helps:
imprimer.pdf
308 Locking diagram
(783.36 KiB) Downloaded 39 times
