Start Stop capacitor replacement and reset.
Larry_98
I own a Citroen Ds4 e-hdi automatic, and have the eco deactivated and start stop not working. Having the check engine message coming up anytime I start the car. It has the fault code P1A9C which made me go ahead to replace a used OEM capacitor. The fault code doesn’t clear afterwards and I need help with a diagbox V9 and the hardware (cables) to reset and clear the fault code. Most PSA car dealerships don’t wanna assist.
- x 8123
Re: Start Stop capacitor replacement and reset.
Depending on whereabouts you are in Germany you may be able to get help from one of our members. The list below gives all the members who are equipped and willing to help and I see there is one in Germany, one in France and two in Austria. If one of them is close enough to you follow the guidance at the beginning and you may have some luck:
viewtopic.php?p=509922#p509922
