Is it possible to just swap the existing halogen headlights in a C5 aircross with the led version of the headlights?
Is it suimply plug & play or is it bit more complex than that?
Cheers in advance
c5 Aircross halogen to LED headlight conversion?
- x 8140
Re: c5 Aircross halogen to LED headlight conversion?
Have a look at this website and you may get some idea,
https://www.ledperf.co.uk/high-power-le ... 38982.html
Mihael_M
- x 37
I assume that you now have H7 bulbs. It's best to read this text from Osram, everything is written inside (Is it suimply plug & play , legalized for the street). The only downside is the price. There are similar ones from other manufacturers.
https://www.osram.com/ecat/NIGHT%20BREA ... P_4069131/
Lber657
Thanks for the replies, what i was referring to was to swap the actual headlight units, not a bulb swap. Apologies for the bum steer.
