again, previously posted i know but just to clear things up a bit more. i changed the accumulator lst weekend and i waw able to pin point the locations of the LHM leaks. It appears to be coming from the metal pipes that connect to the accumulator. would i be right in thinking that these are high pressure pipes?
is it a case of just changing the seals on these pipes? i pressume they are the rubber sleeves 3.5mm and 4.5mm in diameter that i just push on the pipes before tightening the nut again?
any comments woudl be really appreciated.
i did fix one of the leaks with a jubilee clip which i simply added and tightened to the rubber hose which was also leaking.
