Citroen ds3 61 plate low beam not working
Seca
Unread post by Seca »
Hi I'm new to this form I'm hoping someone could tell me which colour the low beam wire is on the passenger side please as it's stopped working I've checked the fuses and they are ok fingers crossed someone can help me
Sloppysod
x 407
Re: Citroen ds3 61 plate low beam not working
Unread post by Sloppysod »
Hi, welcome, hopefully someone will be able to help, I take it the drivers side works.
I take it you have tried the obvious, swapping the bulbs left to right, to see if it's the same. Sometimes bulbs look okay but they are not.
Not recommended [-X , but, there is a way to test bulbs, when you drop a blown bulb it will bounce.......good ones break! #-o
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
Seca
Yes the drivers side works and I've swapped the bulbs and checked the fuses
