Hello
My RT6 radio in citroen DS5 2014 2.0 diesel had a failure, constant bootloop, i foud out it was bad sd card.
Unfortunately i was unable to read out original configuration file.
I managed to replace the card, reinstall software 2.86, ofcourse it was missing lot of configuration items, i managed to get most of them sorted out by manually editing User_config.dat but i have one last problem, some buttons on center console are disabled, exactly dimming funcion, and two, band and tone setting are swapped.
I found out that line 1.8.135 is responsible for button adressing but i cant find right code. Right now i have
"01,02,03,04,05,06,07,08,0B,0D,0F,0C,12,13,11,15,16,17,18,00,24,25,26,27,28,29,2A,2B,19,1B,1C,1D,1E,20,21,22,23,09,2C,2D,2E,2F,30,31,01,03,00,00,00,00,00,00,00,00,00,00,00,00,"
So i come with request, can someone post his good, working values of this line, or maybe the whole user_config file from mirascript.
DS5 RT6 mirascript button configuration
- x 8056
Re: DS5 RT6 mirascript button configuration
Have you asked a dealer if they can provide this coding for you?
