2008 peugeot expert 2.0hdi wont start
kjw95
Unread post by kjw95 »
i have a 2008 Peugeot expert 2.0 hdi that wont start. code p1351, pre/post heating relay circuit. plugs never supplied and code p1350, pre/post heating relay circuit. open circuit or short circuit to earth. i have replaced the glow plugs, glow plug relay and put a new battery in and still wont start. also there is no power getting to the high pressure fuel pump which has also been relaced
x 8149
Re: 2008 peugeot expert 2.0hdi wont start
Have you reset all the fault codes after replacing the parts? :)
kjw95
yes i have cleared all codes and they come straight back on as permanent faults
PaulC5
x 701
Unread post by PaulC5 »
- Is it turning over on the starter ? To start a diesel needs about 300 rpm from the starter.
- is the key being recognised by the immobiliser. Leave the key in the ignition and open the driver's door, a warning message is usually given but if not it might not be recognised ?
- have you tried using easy start in case it is a fuel problem ?
- have you checked any live data during the diagnostic ?
- did it just not start one day or were there any problems before ?
