Part numbers
George-Rawney
Part numbers
Unread post by George-Rawney »
Hi there, I need some part numbers, my AC pipes have been rubbing together and put a big hole in the LP them, it's the long one that goes from the bulkhead to the compressor, and a shorter HP one that goes from the compressor to the condenser..
The vehicle is a 2019 Boxer 2.0 Blue HDi.
I understand it cost a tenner which I'm more than happy to pay if someone could explain how to do it
Also if someone could tell me how to reset my service coupons, or put me on to someone that can do it in the SW London area.... thanks
x 1466
Re: Part numbers
Unread post by xantia_v6 »
Welcome to the forum.
Unfortunately due to a policy change at Stellantis we are no longer able to access the parts database. Don't make a donation just for that or you will be disappointed.
If you are lucky, a member with access may help you out.
George-Rawney
Re: Part numbers
Oh no 🥺 that means it virtually impossible then unless I go to Peugeot
Nevertheless thanks for letting me know,
Cheers pal 👍
x 8137
Re: Part numbers
Hi George and :welc:
While I totally agree with Xantia_V6 regarding donations etc please have a good look round the forum to appreciate the amazing range of topics under discussion. Also the members that do have access to the parts database are generally more inclined to help Donor members (Labelled under your username after donation) than 'just for the part number' visitors. :)
George-Rawney
Re: Part numbers
Ok cheers mate, I'll have a proper look tonight when I get home from work
Thanks 👍
