Hi!
I have this existential question: why does the suspension get more "basketball" like as the height is bigger? the system pressure should be the same, as the weight remaisn equal... or not?
Thanks [:D]
HP suspension existential question
john alexander
tomsheppard
NiSk
Both the above answers are correct and influence the "feeling" of the suspension, in addition raising the car on it's suspension reduces the suspesion travel upwards, as does lowering it reduce the suspension travel downwards. This is why it's not a good idea to make permanent higher or lower adjustments to the suspension by adjusting the height correctors. The car's suspension geometry is correct at driving height, all other heights give some form of negative effect. If you really want to raise or lower the car, you will have to relocate the suspension struts so that you have nominal sphere diaghram position retained.
//NiSk
//NiSk
Dave Burns
No the basic height of the car has nothing to do with suspension pressure.
Suspension pressure increases only with loading of the vehicle, otherwise the weight of the car is the same at any height so it follows that the pressure will also be the same, adjustment to the height being brought about by the volume of oil in the suspension cylinders, that oil is at the same pressure unless the car gets heavier due to increased load.
Sphere diaphragm position will hardly be affected due to the same reason so adjusting the height wont affect them, there will be a very small change in the rears due to a change in leverage of the trailing arms, but the fronts are direct so wont be affected at all.
Dave
Dave
