EPS problem with Grand C4 Picasso (B78, facelift).
ActionJackson
Unread post by ActionJackson »
Hi Guys,
I've run into a problem with the Electronic Power Steering on my 2017 Grand C4 Picasso (B78, facelift).
After old one was broken, a pre-configured replacement steering rack was installed.
The car runs fine sometimes, but then suddenly it runs into a complete fault chain. U1213 or U1212 is usually involved.
Clearing the codes is possible with some persistence but they usually come back fairly quickly.
Contacts have been checked multiple times. I've also fitted a new battery and performed a battery reset via Diagbox. Not the cause.
Suspicion is growing that the steering rack software is from a pre-facelift version of the GP2. Mine is definitely a 2017 build year.
What I read with my VMware Diagbox 9.91:
BSI software 05.71 (96 927 195 80)
Replacement EPS DAE_BVH2: Hardware ID 98 201 566 80, Calibration Number 96 923 733 80, Edition of the Calibration FF.03, SW version D0.11
Can anyone confirm that this EPS software is from the pre-facelift generation?
Thanx in advance!
BTW: Yes, we do drive Citroëns over here — mostly the ones with a bunch of kids. The others go for BMW. :-)
x 8151
Re: EPS problem with Grand C4 Picasso (B78, facelift).
I have moved this topic to the Diagnostics section as you are more likely to get help here as your problem is apparently coding led. :)
ActionJackson
Or maybe I should ask like this...
If someone also has a facelift version of B78 C4 Grand Picasso and a Diagbox:
Could you read out your Power Steering Hardware/Software Version (see numbers above)?
Thank you!
