8 Speed automatic gearbox u1209 +p1718
LEOAKIE12
Unread post by LEOAKIE12 »
Hi I have peugeot rifter 2022 model with 8 speed automatic gearbox, mechanic took it in for gearbox issue, as far as i am aware he did work on valve body, then car goes into P and doesn't not come out from park. hope someone can help.
x 8165
Re: 8 Speed automatic gearbox u1209 +p1718
When you say it doesn't come out of park do you mean the gear lever won't move, or moving the gearlever does not change the gear? :)
LEOAKIE12
I had to disconnect the tcu to manually put the car in N so I have towe it out of that garage! But once I reconnect the tcu/tcm it will straight away go into Park. Clear all codes in diagnostic tool start the car press brake move the gear lever inside the car to n or d or r the gets p1209 code and ?? warnings on dash board. Inside diagnostic tool it shows gear postion correctly but car does not go into any gear and suck in p.
