Hi all,
I recently had the dpf removed and ear blanked and ecu remapped on my 2010 Citroen C5 estate.
Initially I thought the dpf was blocked and causing the ems fault warning to illuminate on the dash under hard acceleration, hence having the dpf removed.
Sadly the problem still persists and I have been told it is the turbo and will need replacing, before I go to the expense and hassle of doing this, is there something else that might be causing the problem and if so what should I be looking at.
Hopefully as always someone on here has the answer or suggestion as to what to look at.
John
Turbo related problem
- x 8079
Re: Turbo related problem
It is Forum policy not to comment on any vehicles which have had regulatory breaking modifications.
Spence4032
Cheers and thanks for letting me know.
