C5 X7 AM6: driveshaft completely stuck in the gearbox
marsalek
x 19
Unread post by marsalek »
Hi guys,
I am currently replacing the left-hand driveshaft on my C5 X7 HDi 240 with the AM6 automatic gearbox. The driveshaft is completely stuck in the gearbox :-(
While giving it a hard yank, the inner CV joint pulled apart, so now only the inner joint cup (housing) is left stuck inside the gearbox. Looking at the new driveshaft, I noticed there is no groove for a circlip, so it seems it is just a push-fit. There is a tiny bit of axial play (a few tenths of a millimeter), and it feels like the splined counterpart inside the differential is moving slightly along with it.
There is barely any room to work around the inner joint cup :-( What is the best way or tool to get this remaining piece out? Any tips or tricks would be highly appreciated!!!
Thanks a lot,
Karel
x 8086
Re: C5 X7 AM6: driveshaft completely stuck in the gearbox
You may get an idea from this video:
marsalek
x 19
Hi Mick, thank you for the video! I sprayed some penetrating oil and wait over night with the hope, it will help tomorrow :-)
x 1452
Unread post by xantia_v6 »
The driveshaft splines are not behind an oil seal, so are exposed to moisture and have probably formed a rust bond with the differential output shaft.
A sharp blow will probably work better than brute force to break it free.
Kees
x 147
Unread post by Kees »
There is an o-ring on the drives haft to prevent this, but I had this comes of one time when i removed the drive shaft and yes, then it's possible what you saying.
