Cooling fan problem on DS3 1,6HDI-E from 2012.
as5991
Unread post by as5991 »
Hi, hope you can help me.
My DS3 1.6 HDI-e from 2012 will not start the engine cooling fan. The engine runs in limp-mode. Showing ENGINE FAULT 5 sec after start.
My diagbox v9,91 shows 3 error codes:
p0493
p0691
p0693
I can not reset the codes.
I can't activate the fan in actuator test.
Air con does not work, (that is a minor problem for me)
I have replaced the heater resistor unit.
I have replaced the BSM box.
If I shortcut the two pins in the big connector on the fan resistor, the fan runs. So fuse and motor must be OK.
I have measured the 3 wires from the resistor to the ECU, I guess they are for hi/low and feedback/status.
The 4. Wire comes from the BSM box with 12V when ignition is ON.
If I start driving immediately after starting the engine, It does not go into limp mode before the speed is near to zero km/h. I can't do this with the new resistor.
Any help would be much appreciated.
x 1458
Re: Cooling fan problem on DS3 1,6HDI-E from 2012.
Unread post by xantia_v6 »
Despite the errors, you should be able to see some live data in the engine ECU giving the state of the fan.
Here is the wiring diagram:
1320 is the engine ECU, 1529 is the fan control module.
PaulC5
x 681
Unread post by PaulC5 »
What are the definitions of the error codes, saves us having to look them up ?
Berktuka
Unread post by Berktuka »
Hi!
Did you solve this proble? I have same issue! A have changed tha fan, the resistor, check the wires and connectors, relays , fuse, BSI. Everything is ok.
The fan is not working, car is limp mode...
Berktuka
as5991 wrote: 15 May 2026, 08:34 Hi, hope you can help me.
p0493
p0691
p0693
Did you solve your problem? I have same issue. A have replace fan, resistor, BSM , check the wires . Everyting is ok seperately . But the problem still exist...
