Peugeot 207 2012, not starting
Liambennett
New User
Unread post by Liambennett »
Hello all, this is my first time on here also a new driver so if what I say about my car doesn’t make sense bear with me. Basically my Peugeot 207 2012 would not start you turn the key no response, all fuses and battery have been checked nothing wrong with them. There is no power even to the obd port so I can’t use a scanner. The only things that work in the car are the locks and the hazards any help would be appreciated as iam stuck of what to do.
x 8165
Re: Peugeot 207 2012, not starting
Hello and :welc:
You need to give full details of your car to avoid people going down irrelevant paths with your problem. The list below shows what is needed. You say nothing happens when you turn the key, do you mean no lights on the dashboard at all or no engine turning when trying to start?
Make/Model
Year
Engine type
Gearbox type
Body style
LHD or RHD
RPO number which can be found on the tyre pressure sticker on the door pillar, post a picture of the sticker if you are not sure.
Whether the vehicle has Electronic Stability Control or not
