2011 C3 Picasso Steering Wheel Trim
jesschap
Unread post by jesschap »
After slicing a finger, I've just had to remove all the Chrome effect material from the steering wheel insert on my C3 Pic.
It now looks a bit naff.
Is this part replaceable or is it integral to the wheel? I've tried to remove the actual trim and I assumed it would pop off with a bit of force but that doesn't appear to work. :-k
TIA
x 1931
Re: 2011 C3 Picasso Steering Wheel Trim
Unread post by Paul-R »
I'm pretty sure that it's part of the steering wheel and not replaceable separately. I have a similar trim the wheel of my C5 X7 and that's part of the wheel. Fortunately it isn't (currently) dangerous to my fingers.
PaulC5
x 670
Unread post by PaulC5 »
Could you file off the sharp bits and fit it back ?
jesschap
No sharp bits left to file off ......I've removed the offending finish but it's a white blob of plastic. I might just paint it matt black or something. The wheel looks easily removed so I suppose I could just mask if off and spray it.
