New owner 2014 308 1.6hdi - needing advice on correct clutch kit to order
neon989
Unread post by neon989 »
Hi all,
I have recently bought a 2014 308 1.6hdi - I have a dull thudding when coming to a stop, a vibration at idle, creaking/cracking/spring noise when going on and off the clutch, difficulty engaging reverse and 1st gear, and intermittent metallic clunk when changing gears. Clutch pedal is very high and grinding noise and sometimes doesnt always return fully. So I am looking to have the clutch and flywheel replaced.
It is the 1.6hdi engine 6 speed manual - I am unsure of which clutch kit to order as there are a couple of different ones I think one with 21 teeth and one with 26.
The VIN number is - VF3**************[VIN obfuscated, can be read by forum staff] and the reg is AE64 TFK.
If anyone could give me some pointers in the right direction as to my specific model would be grand.
Regards
Alex
PaulC5
x 682
Re: New owner 2014 308 1.6hdi - needing advice on correct clutch kit to order
Unread post by PaulC5 »
Who is going to fit the new clutch ? If a garage you should let them supply the parts so their warranty covers the parts and not just their labour.
