Problem with parking sensors
Dark
Unread post by Dark »
Peugeot 2019 3008 GT p84 1.6 THP 164 EP6FDTM 6 speed automatic girpox
The car was involved in an accident on the front right bumper, and since then these errors have appeared and cannot be erased
UF100
B1225
B1226
B1251
B1245
B1210
PaulC5
x 714
Re: Problem with parking sensors
Unread post by PaulC5 »
What is the definition of all those fault codes, saves anyone having to look them up before being able to help ?
Has the car been repaired yet ?
Dark
No The car has not yet been repaired.
B1225 Inner Front Right Parking Assistance Sensor Fault
Permanent
B1226 Outer Front Right Parking Assistance Sensor Fault
Permanent
B1251 Front Right Lateral Parking Assistance Sensor Fault
PaulC5
x 714
Looks as if the car needs to be repaired. There might be damage to the sensor wiring in the bumper and/or the sensors themselves are damaged. You could swap the left side ones over to the right and see if the faults swap sides to check the sensors.
