Following on from my previous post a few weeks ago,my problem fan is back.1 of my cooling fans began to rattle & squeek,& run slower than the other 1.Then after a few days it was ok again.Now,its on it last legs again,spinning at half the speed of the other 1,& making a hell of a noise.I would say that the bearing has gone,as it is quite wobbly.
I will have a look around the scrappys at the w/end for another 1.Are all the fans the same on each model,or are they different??Do i need one from another TD with a/c?Or will any fan be the same??
Cooling fans again
PowerLee
