Is there any instruction on how till drain/refill coolant? Volume? Type?
/Ake
C4 1.6Hdi 2011 Draining/refilling coolant
akerolf
- x 8085
Re: C4 1.6Hdi 2011 Draining/refilling coolant
As a donor you have access to the resources section and in there you will find the procedure for replacing the heater matrix. Obviously you only need the relevant sections of that description but it does include details of replacing the coolant:
viewtopic.php?p=598999#p598999
