Peugeot 307cc
Tolly179
Peugeot 307cc
Unread post by Tolly179 »
Right I changed the switches in my center console for the roof and windows. The windows switch didn’t work. Today I was retracting my roof and with someone about I released the button. Not looking I grabbed the window switch and they raised slightly. I lowered them and then the roof wouldn’t work either closing or opening. I had to manually close it. What could have triggered this as I haven’t had an issue with the roof since owning the car !!!??!!
x 1459
Re: Peugeot 307cc
Unread post by xantia_v6 »
You will probably need to get the car connected to a diagnostic to read any fault codes and check the state of all the switches. It would be worth checking the fuses first.
Tolly179
Re: Peugeot 307cc
Thank you for that. I’ve found out where th fuses are for the roof and I’ll check it on Sunday.
