Has anyone encountered the problem (fault code) P0238 on peugeot 207 1.6hdi 109ks and if you did, what did you do to get rid of that problem?
Explicitly what happens: the demanded pressure and the obtained pressure go symmetrically until the error and then it is like this - the demanded pressure is 2400mbar, and the obtained pressure drops to 1000mbar, and then when it release that trouble/malfunction the obtained pressure returns to the required (2400mbar).
P0238 fault code
- x 8121
Re: P0238 fault code
You may get some ideas from this video:
