Xantia front sinks when driving
Jippington
Unread post by Jippington »
Hello, I have a problem where the front of my car gradually sinks over about 10 miles.
The problem started after changing a drop link yesterday, after which the front wouldn't rise at all. I have now moved the height position clamp and now rises properly and only seems to sink after driving.
I'm pretty clueless about what it could be so any ideas are welcome!
aerodynamica
x 215
Re: Xantia front sinks when driving
Unread post by aerodynamica »
Hi, have you checked that the plastic link to the height corrector is still attached?
Graeme M
Jippington
aerodynamica wrote: 26 Apr 2026, 19:30 Hi, have you checked that the plastic link to the height corrector is still attached?
From what I could see it was still attached, gave it a blast of WD 40 while at it
x 1450
Unread post by xantia_v6 »
Take a good look at the arm that is welded to the clamp on the ARB and make sure the it is not about to fall off. Also check that the clamp is actually gripping the ARB firmly.
