Peugeot 3008 rt6 radio blank
MrPid
Got a 2014 peugeot 3008. The radio and satnav stopped working on Sunday cd keeps trying to eject every 20 seconds. Looks like might have a corrupt micro sd card . Where can I download a firmware to load a new sd card. Thanks in advance
- x 1942
Re: Peugeot 3008 rt6 radio blank
I'll move this into a more suitable area in the Audio & Telematics section.
- x 1942
If your USB socket is still working and the screen will allow you to see the options I would use Mirascript first of all to download your configuration information. I did this on my C5's eMyWay/RT6 head unit (HU) although it was only as a backup in case my fiddling around with the HU needed undoing! The only other thing I did with Mirascript was to remove the need to input a security code when updating maps. There's a lot more in Mirascript but I haven't had the need to change anything else. Nor the nerve to be honest.
I wish we had some better information on Mirascript here but there's not much and nothing with everything in one place. If you do a forum search for Mirascript and Mirascripts there a few posts which might be worth looking at.
MrPid
Thank you will have a look. Can't see what version it running as screen is blank
- x 1942
That may prove a problem trying to use Mirascript.
MrPid
Is there any other way of getting it working again.
- x 1942
I think you're going to have to send it off to be repaired. I have no personal recommendations but here are three results from a quick search of the internet.
https://www.lesevans.co.uk/
http://revivecaraudio.co.uk/read-more/
http://www.rwer.co.uk/services_carradiorepairs.htm
Read the posts in this thread for interest. viewtopic.php?p=865313#p865313
One further thought. Hopefully your display hasn't broken as well!
