Fuse box not connecting with ecu campus
Sladedave
Hi . I have a 2007 Citroen Picasso exclusive. Has a fault where the cambus is not communicating properly with ecu . And code reader says it’s the engine fusebox . I’ve changed both fuseboxes including the one over the battery . Still has the same problem . Saying bad earth to fuse box . Exactly where is the earth wire to fuse box ? Can I bypass it ? Thanks in advance
- x 8128
Re: Fuse box not connecting with ecu campus
Which engine and gearbox combination do you have? That can affect the vehicle's loom
