Renault Clio Mk2 Earth Cable
Sb1985
Unread post by Sb1985 »
My earth cable is no longer working due to corrosion.
I cannot find a direct replacement online. Any help would be great.
x 8130
Re: Renault Clio Mk2 Earth Cable
You need to confirm which year, engine and gearbox you have, together with which actual earth cable you are asking about. :)
Sb1985
Morning. Its a 2003 1.2 16v petrol 5 speed gearbox.
Thank you
x 8130
Ok, is it the batttery to body cable or a body to engine or gearbox cable? :)
x 1463
Unread post by xantia_v6 »
Is the problem just with the connector clamp on the end of the cable? If the cable itself is not corroded, or there enough spare length to cut down, then you should be able to fit an aftermarket connector available from a motor factor or online supplier.
Sb1985
I'll attach some images. It is the battery to gearbox/engine wire.
x 8130
This one from a mk4 looks very similar. You could ask the seller to confirm the dimensions. :)
https://www.ebay.co.uk/itm/317462011457
Sb1985
Thank you
